Results 1 to 10 of 13
Thread: Chlorine generator question
    Jacob99 is offline Subscriber Thread Analyst Jacob99 0
    Aug 2011
    Massachusetts
    Default Re: Chlorine generator question
    Interesting....thanks for the reply. The pool I'm looking at is a 30' round above ground Tahitian which is made by Wilbar. It carries their 2nd best warranty...lifetime on walls, and 60 years (5 full) of other parts. However, it clearly states, "Salt Chlorine Generator Systems & any other like system that uses salt to purify the pool raises the risk of
    corrosion substantially.ALL WARRANTIES ARE VOIDED IF SUCH SYSTEMS ARE USED!"
    I don't know why it's such a big deal, it's heavy gauge steel with their plastic coating on the walls, etc.
    With the automatic chlorinators, don't they have one that uses liquid chlorine instead of the pucks, or does that automatically become an injection system?
    Quote Originally Posted by Jacob99 View Post
    THAT is why. There are composite pools that are fine for use with a SWCG so shop around.
    manual Peristaltic pumps or devices like the Liquidator. Not sure what you mean by "injection system".
    Aug 2011
    Massachusetts
    So the difference between this with 9 layer PlastiGuard coating:
    http://www.familypoolfun.com/shop?ca...7&product=TF15
    vs. this with Resin coating:
    http://www.familypoolfun.com/shop?ca...&product=MAT15
    is what makes a pool okay for use with SWCG? That really blows because the Matrix only comes in 28 and 33 round. I really have my heart set on a 30 round!
    Largo, Florida
    I think the latter is made entirely of resin rather than resin coated steel.
    Edit: I guess you're right. The side of the page indicates it's got "steel walls". I wonder if that's an error since in the details it doesn't say so.
    BigDave's Avatar
    My guess is that the walls are coated and sealed steel. I have a hard time believing that any resin sheeting would have the necessary tensile strength to hold a pool.
    ..Perhaps if it had kevlar mesh molded in?
    If you are set on getting this pool then a generator is out.
    If this is your first pool, you can start by using bleach or Liquid Chlorine and seeing if testing and adding as you need is easy enough for you. I find it's not a burden. If you learn our B-B-B system, which is very easy, you may find the SWCG isn't necessary. I would LOVE to have one but I cannot justify the cost (for me) because it relieves me of very little work. OTOH, I was EASILY able to justify a robotic vacuum rather than manually vacuuming and brushing the walls.
    But that is me, and my needs.
    I don't know about the Liquidator but I tried an earlier passive system that used pump suction, replacing the drain plug on the pump. It was, for me, a total waste of $$$ and that on-line store stopped selling them. From what little I hear, the Liquidator is better.
    Also if you haven't done so, invest in a good test kit. We recommend the Taylor K-2006 or K-2006C. PoolDoc and Watermom have links to them on their signatures and if you use the link there's a small commission paid by the store that helps pay to maintain the forum.
    Aug 2011
    Massachusetts
    Thanks everyone. I will definitely buy the test kit, but I think I'll work on actually getting the pool first. Good to know that forum gets a little piece when buying through the links on their sigs. This place rocks, and I'm happy to help out where I can. The Liquidator does seem like a convenient thing to have, but I can't find reviews about how they hold up year to year. Also, would I be able to leave it outside over the winter, or would I need to bring it in or winterize it somehow?
    Also, I've got a really stupid question about BBB. When putting bleach into your pool, do you just lean over the side and dump it in? I know you have to be careful with splashing on the liner, clothes, etc, but if I dump a gallon of bleach over the sidewall on a 30' pool, won't I need to stir it, or do I just pour it in when the pump is running and that helps distribute it? I searched for an answer on this because quite frankly I was embarrassed to ask as it's probably common sense, but being new to pools in general, I want to make sure I understand everything. Once I pour it in, should I wait a little while before going in the water?
