Results 1 to 10 of 15
Thread: Finaly got my Salt system working
    Jul 2011
    SoCal
    Default Finaly got my Salt system working
    Hi, first of all, i want to thank this forum for helping me bring my pool back to life.
    So, i spent the summer without my salt system working and used bleach and it worked awesome. I finaly got around to ordering my circuit board because it was to damaged to fix. I must say, i love the salt sytem so far. I haven't had to add bleach for a month now. It works awesome! The only issue that i have is that i have high levels of salt. I've double checked with test strips and the chlorinator is spot on. It was my understanding that my generator wasn't supposed to work when levels were above 4000 and i'm at 4100 to 4400. My high salt level doesn't come on and it keeps my chlorine at 5ppm. It's working so i won't complain. My pH and calcium is on the high side but my pool is sparkling clear. Here are my numbers.
    fc-5
    pH-7.8
    TA-100
    ch-500
    salt-4300
    water temp-70
    I have tried to lower the pH but it won't stay down so i have left it between 7.6 and 7.8
    23k gallons - Aqua-Rite salt system
    pebble-tec inground
    hayward super clear with paper cartridege filters - 1/2 hp pump
    May 2010
    Default Re: Finaly got my Salt system working
    As a general statement, the test strips for salt are probably not that reliable. And for what it's worth, the little battery powered testers used by the pool stores also vary. I would also ponder a guess that if your salt level is too high OR too low, the system will in all probability still work, just not as efficiently.
    I treat my SWCG kinda like my spouse, she is the only one that I have to satisfy. In other words, as long as the SWCG is producing chlorine and working well, and the high salt and low salt lights are not coming on, you're Golden.
    Quote Originally Posted by BigTallGuy View Post
    FWIW, the salt test strips are actually titrators and, if used properly (let them sit in the sample for a full 10 minutes) are very good and less prone to operator error than the trickier chromate/silver nitrate titration test. Salt meters range from excellent to terrible and a lot depends on keeping them calibrated against a standard salt solution.
    May 2010
    HI Evan, thanks for your insight, I love this Forum. Would you please be so kind as to explain the difference between the two, and what to look for when we go to the pool store?
    do you mean between salt strips and titration test or salt meters?
    For meters I have found the MyronL and the Oakton SaltTestr11 to be reliable AS LONG AS THEY ARE KEPT CALIBRATED WITH STANDARD SOLUTIONS ON A REGULAR BASIS! FWIW, the Hayward/Goldline salt meter is a rebranded Oakton unit (but not sure which model--I think they are using the lower end Ecotestr now--they used to use the SaltTestr).
    May 2010
    I'm Sorry Evan, Please forgive me, I misunderstood your post. Is there any difference in Salt strips, or are they all about the same? I thought I read somewhere on this forum that test strips were largely inaccurate, but that may not have been Salt tests.
    I guess I'm looking for a "best bang for your buck" break-down on salt testing. Best to worst, and cheapest to most expensive. I need something that is more reliable than the pool store.
    Thanks for your help.
    Quote Originally Posted by DirtRider67 View Post
    fc-5
    pH-7.8
    TA-100
    ch-500
    salt-4300
    water temp-70
    The Aquarite does not cut off until about 4600 ppm so you are still withing range. Keeping the pH between 7.6 to 7.8 is ideal for a SWCG btw. What is your CYA? With the Aquarite you want to to be 80 ppm. IF you drop your TA down to 70 ppm you will have better pH stability, btw.
    May 2010
    Thank you Evan. I'll see if I can find some and post back with the results.
    Realize that a chemical test (salt strips or titration) is testing specifically for chloride ions while a meter, whether stand alone or a readout in the SWCG is testing the conductivity of the water, making some assumptions about the makeup of the ionic material in the water so the two will not always agree. Also, temperature does affect conductivity so it will be lower when the water is colder and higher when the water is hotter which is why it sometimes seems that the salt level is dropping in colder weather when measured with a meter or the cell readout. As far as your salt system is concerned it is since the conductivity is lower but if you add more salt you will find that the salt is too high once the weather warms up.
