Results 1 to 10 of 18
Thread: Pink slime!
    Jul 2011
    Boca Raton, FL
    Default Re: Pink slime!
    Oddly, my pool's pH read 7.4 today -- same as it was three days ago! While I haven't been using the waterfall, I've never had the pH be stable for three days in a row. Weird! Pool temp is 79, no change there. Does calcium somehow stabilize pH, too?
    My FC hit 4.5 today, so I'll readjust the SWCG back to its original setting (50%) and see if the FC stays the same.
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Quote Originally Posted by famousdavis View Post
    A waterfall aerates the water increasing the rate of carbon dioxide outgassing which causes the pH to rise. No mystery here. Lowering the TA level reduces the over-carbonation of the pool so reduces the rate of pH rise, but reducing aeration sources also helps. The SWCG also aerates the water with its hydrogen gas bubbles and may also have some chlorine outgassing, both of which cause the pH to rise, if the pipe run between the SWCG and the pool is relatively short.
    Jul 2011
    Boca Raton, FL
    Thanks chem geek.
    Taken what you and waterbear have written, I can conclude that the pH stability was borne from stopping my waterfall and by tamping down the ontime for my SWCG -- two causes for pH rise. This morning I opened the valve to the spa just a little so the water is replaced with filtered/chlorinated water, but it's just a water drip now, not a waterfall. ;-)
    Forgot to mention that I used to measure muriatic acid until I read (somewhere here, maybe?) that adding the measuring step may cause more harm than good because it's an extra step that might lead to an accidental spillage of acid. So, I've just guesstimated my acid additions (with fairly consistent results - my pH would fall back to 7.2). I'll try guesstimating a smaller dose of acid from now on. Measuring acid is actually fairly easy by just looking at the acid container's liquid level, and calculating what a few cups poured out would look like. The thing I haven't done is perform an actual acid demand test to calculate with more precision just how much acid I should add. I'll do that the next time my pH needs downward adjusting, just so I can better estimate my acid demand needs.
    Fine work, gentlemen!
    Thanks chem geek.
    And the second reason is why the CYA should be at the maximim since it will mean that a lower on percentage will maintain the desired FC level. Lower on time means less aeration means slower pH rise.
