Why would you have chlorine in your well water? Are you using a chlorinator on your well system?
~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
I actually thought the DPD powder added chlorine. Epic Fail! Maybe I should actually read the book instead if just the inside cover of the test kit.
LOL, it helps![]()
Just to clarify my post above, I have had the chlorine levels in my pool up into the 30-40 ppm range for extended periods of time (don't ask!) and it only took one scoop of powder to produce pink. It is possible, and I think one of my fellow mods is actually trying this out for clarification, that extremely high chlorine levels may bleach out one scoop of powder. However, even if that's so, you shouldn't find that level of chlorine in any source of drinking water.
Not answering for Jacob99 but it's common for well water to be chlorinated. We have a chlorine injector that uses diluted household bleach which it injects into the line that brings the well water into the house. That chlorinated water goes into a 150 gal holding tank. When a faucet is opened, water is drawn from the holding tank through a very large carbon filter into the house lines. The chlorine in the holding tank is around 8 ppm. What I draw at the sink is 1 ppm or less.
When I have to top off the pool I turn off the chlorination system and use straight well water. We don't have metals in the well and its alkalinity is right around 50 ppm, perfect for my pool. I usually adjust the FC to 5 ppm after a refill and let it drift back down to its normal 3 ppm.
Didn't mean to highjack your thread, Jacob. Having a good test kit is really very useful when you're using well water.
No worries. Pretty interesting actually. I'm not sure how mine works to be honest. All I know is that I have to dump water softening salt crystals into it every few months...
So, should I be testing my well water for alkalinity? I'm not planning on filling my pool with it, but will probably supplement with about 5000 gallons over the course of a few days. I need almost 24000 gallons, and (3) 6500 gallon trucks will give me 19,500 gallons. I plan on topping the rest off with my well water.
It wouldn't hurt to know what it is, but that's not a priority right now, since only about 1/5 of your total volume will be well water, and the rest water trucked in--the end result will be affected more by the trucked in water. Either way, it's an easy fix. A more important thing to know is if there is iron, copper, manganese, or any other metals in your well water--that WILL be a priority when you fill with it.
No, the calcium hardness is only for calcium. Iron, copper, and manganese require special tests that are not in the K-2006. You can get the pool store to test for them, though.
If your pool is filled with water that has gone through the softener, there should little if any copper, iron, or manganese present. One test for metals, is to fill a CLEAN 5 gallon white bucket with water, add a tablespoon of bleach, cover it, and let it stand for a day. Metals will tend to settle to the bottom. If you want to take it a step further, add a couple of tablespoons of washing soda when you add the bleach. Be sure to mix afterwards.
PoolDoc / Ben
