Re: buying house with salt water pool and a fafco solar sysytem any advice?
thanks will do when we close on the house in late may. My questions were with the solar system and the leaks and wondering if this was a common maintence issue? I assume that i will have to learn about salt water pool care as I have had experience with an above ground pool in Wisconsin which is a much different climate. Thanks for your response
rh
