Results 1 to 10 of 11
Thread: Pool Help/Advice for new pool owner
    Apr 2012
    Panama City Beach, Fl
    Default Re: Pool Help/Advice for new pool owner
    I will be digging my hole tonight to confirm the water column depth.
    If I can drain, i will, if not, I will start with the bleach. I ordered the Taylor K-2006 and OTO kits from you sig link through amazon. They said it should be here by friday.
    Is it ok to start with the bleach? How many gallons per evening would you add? (Note: I have a 7k gallon pool).
    Just to make sure I am following you, If I add one pound of cyanuric acid into a 7,000 gallon pool, it would raise my CYA as followed:
    120,000/7,000 = 17.14, so my CYA level would raise 17.14 ppm ????
    Also, confused on the bleach, so 1 gallon of 6% bleach will raise a 12k pool 10 ppm ???
    120,000/x = 10ppm so.... x = 12,000 gallons.
    You said that 1 lb of cyanuric acid = 1ppm, how much does a gallon or quart weigh?
    In Ground, 6,900 Gallon Gunite pool with tile trim, Haywayd EcoStar SP34000VSP Variable Speed, Aquarite 25k SWCG, North Florida
    Quote Originally Posted by Wraypau View Post
    One pound of CYA in a 7K gallon pool will raise your CYA by just over 17 ppm, so you've got that one right. However, 1 gallon of 6% bleach in 12K gallons will raise your FC by 5 ppm. One gallon of 6% bleach in a 7K gallon pool will raise your chlorine by approx. 8.5 ppm.
    One gallon of water weighs approx. 8.4 pounds....
    Maybe he is asking how much a gallon or a quart of CYA weighs? However, CYA is sold by the lb. not by gallons or quarts.
    Apr 2012
    I dug my hole to 4 ft. Water filled it so that it is only 2 ft deep. Looks like I will be putting the bleach to it. Thanks for all the help.
    That would be a "big 10-4", unless you want a pool-shaped concrete boat in your back yard!
