Results 1 to 10 of 19
Thread: algae control question
    May 2012
    Winston-Salem NC
    Default Re: algae control question
    Hi Alison, and welcome to the Pool Forum!
    As soon as you get your kit, run a full set of numbers and post them. It is really impossible to help much without those numbers. For now, what readings do you get with the OTO kit? What source of chlorine have you been using? Any idea what your CYA reading was when you closed in the fall? It would be good to know that to compare it with your current reading.
    What kind of filter do you have and what size of pump?
    Hope the kit arrives soon. We'll be here and ready to help!
    Thanks watermom. I'll post the numbers when I get the kit. But is there somewhere that lists "if your pH is x and your pool is y gallons, add z ozs of muriatic acid to change it to pH 7.6"? (just an example). I feel like I have seen this somewhere...other than the back of the package of whatever chemical I am holding! I guess what I am looking for is a collection of tables for each of the main chemicals we use.
    Alison
    Yes, there's one at thepoolcalculator.com, but I like the Beachcalc linked at this thread better: http://richardfalk.home.comcast.net/...achCalc262.exe
    That's the one I like better, too.
    Richard hosted it, but Michael Smith (mwsmith) wrote it.
    May 2012
    Winston-Salem NC
    Thank you for the replies! I have a salt water system so the poolcalculator.com link is closer to what I was looking for...but I was actually hoping to find good old fashioned tables that I could print out, laminate and keep handy! (I am pretty old school about such things.) I can't figure out an appropriate search term to hunt for them. Perhaps I need to find a book about pool maintenance? (But so much would be wrong...)
    Or maybe I need to spend an hour with poolcalculator and run a bunch of variables.
    Any ideas?
    Alison
    BigDave's Avatar
    Quote Originally Posted by alisonquilts View Post
    ... But is there somewhere that lists "if your pH is x and your pool is y gallons, add z ozs of muriatic acid to change it to pH 7.6"? (just an example)...
    It's interesting that you use pH as an example in that pH has got to be the least predictable value we measure in pool care. pH is affected by many interactions in the pool and trying to calculate the affect of a treatment is rough estimation at best.
    Your K-2006 does have an answer to this: it includes Acid and Base Demand Tests. These let you measure the amount of treatment you'll need to adjust pH. It works like this: Measure pH, if it's low, add Base Demand counting drops until pH is where you want (Acid Demand works same way) - look up number of drops of treatment in the tables in the book that comes with K-2006 and find treatment dose.
    The book has tables for other treatments as well - This may be what you're looking for.
    Treat the doses you get from these tables as loose approximations only. They are helpful in determining how much of a chemical to buy and have on hand but less useful when it comes to actually treating your pool. At most, use half of any recommended dose, let it mix, measure, redose. This way (measure, dose, measure, dose, ...) you can avoid the inevitable see-saw of chasing numbers.
    The other end of Big Dave's answer is...after testing your water on a daily basis for awhile, you'll learn the pattern of your pool...(ie. One jug of bleach adds "x" amount to MY pool, one pint of acid drops MY pH by "x" amount, etc.)
    Everybody's pool is a little different.
    Don't use the book that comes with the Taylor kit. It is not helpful and will lead you astray. That was one reason Ben used to sell kits so that he could leave that book out of the kit as it causes lots of confusion.
    BigDave's Avatar
    I should have pointed out in my post that (as Watermom and aylad suggest) you don't need those tables.
    The best way to make your pool eaisiest for you is to learn what it needs and how it reacts - daily testing and treatment will give you the practice you need to get a "feel" for your pool.
    May 2012
    Winston-Salem NC
    OK. I think I have some idea now: When I get my (longed-for and much anticipated) kit I will be able to get accurate measurements. When I have accurate measurements I can use poolcalculator.com to figure out my response (under-dosing, then testing, then re-dosing if necessary). When I have done this enough I will develop a sense (similar to using the Force) whereby I will see a result and have an intuition about what to do in response. I will then teach it all to my husband...
    About the tables I am so hung up on - I think I will just copy the relevant bits off the backs of the various chemical packages into one document so I'll have a basic guide, since there doesn't seem to be the professionally compiled lists I expected.
    Thanks for your help. If nothing else you have reassured me that it is not at all unnatural to be confused at this point!
    Alison
