Results 1 to 9 of 9
Thread: Salt Level not showing actual values
    Lexington, SC
    Default Re: Salt Level not showing actual values
    I have been having the same problem. I have an Aquarite Goldline generator. I replaced the cell about a year ago. It was working fine until lately it showed low salt levels at about 1800. My local pool store checked the salt and it read 4000! There is no chlorine being generated. I inspected the cell and cleaned it with a muriatic acid solution. It still reads low salt. Could it be something else like the flow sensor?
    mas985's Avatar
    Pleasanton, CA
    Probably not. A flow censor problem would alarm as no flow. The low salt readout is usually due to a failing cell or a calcified cell.
    Mark
    Lexington, SC
    Well I bit the bullet and ordered a replacement cell today. I was hoping for a less expensive fix. Thanks for the advice.
    mas985's Avatar
    Pleasanton, CA
    Are you sure you cleaned the cell well? A cell should last much longer than a year.
    Mark
    Virginia
    Quote Originally Posted by BogeyGolfer View Post
    Quote Originally Posted by mas985 View Post
    Unless it was one of those new "economy" cells only designed for one year, it should be under warranty.
  1. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  2. Recommended values for a SWG pool
    By Charlie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-24-2011, 08:25 PM
  3. Salt level?
    By court475 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2009, 01:11 AM
  4. my salt level
    By Bowlin in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2006, 02:44 PM
