Thread: Need help with cloudy water
    Jul 2012
    Savannah, New York
    Default Re: Need help with cloudy water
    This afternoon everything has changed again! The alk is up and the PH is up, I'm aerating and frustrated.
    Were you able to get one of the kits Janet recommended above? We need some good testing numbers to be able to help.
    Quote Originally Posted by Yvonne View Post
    Aerating is going to raise your pH. If you don't want it to rise anymore, then point your returns downward so they're not rippling the water surface, or stop whatever aerating method you're using.
