Results 1 to 10 of 18
Thread: My First post/Question
    Jul 2012
    Pennsylvania
    Default My First post/Question
    I posted my first question here last night waiting for moderator approval but it seems to have dissapeared?
    Default Re: My First post/Question
    There are several buttons around the edit box that appears when you post. If you press the wrong one, your post can disappear. My personal favorite is to press the "+Reply to Thread" button, instead of the "Post Quick Reply" button. I must have lost a dozen posts this season that way.
    However, now that I'm 58, I can blame it on "flatulence of the brain, characteristic of aging seniors".
    Jul 2012
    Pennsylvania
    Thanks for the Welcome!
    My question is this...I'm looking for an AG pool and trying to decide between Oval(16x24) and Round 24'. I have been looking at Doughboy and Buster Crabbe but can't seem to find anything about Buster Crabbe. Doughboy seems to be top notch. BTW this will be our first pool so we really don't know anything! Any advice appreciated.
    Jul 2012
    Pennsylvania
    I'm right behind you at 54...now, what was I talking about ;-)
    I don't know anything about Buster Crabbe pools so can't help you there. As far as oval vs. round --- maybe think about which one would best fit the space in your yard where you plan to install it. Personally, I've always had round pools. Maybe you'll get some other opinions about this.
    While you are in the planning stage, I want to make a couple of suggestions to you. Go ahead and order a good test kit before your pool is up so you'll have it from day one. The one we recommend is the Taylor K-2006 or 2006C which you can get through the testkit link in my signature below. Also, do a lot of reading here on the forum and also on our sister website www.poolsolutions.com. (Until your registration is completed, you'll need to log out to be able to see the rest of the forum.)
    Jul 2012
    Pennsylvania
    That's what worries me about Buster Crabbe pools, there is not a lot of information out there about them. I know this may open a can of worms but what's better, steel or aluminum? I read a big long thread about it but there didn't seem to be any conclusion.
    I can't help with the DB vs BC question, but your membership is upgraded. -ben
    Jul 2012
    Pennsylvania
    Thanks PoolDoc!
    BigDave's Avatar
    On Round vs. Oval, If you can fit a round, get round. They are simpler, cheaper, and there's less to fail.
  1. New Member-First question-post in way of return
    By handihomer in forum Above-Ground Pool Construction & Repair
    Last Post: 08-22-2012, 03:16 PM
  2. First post! question about the perfect pool bottom and moles
    By Leehicks79 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-13-2012, 09:24 PM
  3. First Post
    By ssowell in forum Intex-type Pool Setup & Operations
    Last Post: 06-04-2012, 01:50 PM
  4. My First Post
    By nKhona in forum In-Ground Pool Construction and Repair
    Last Post: 09-06-2011, 08:03 PM
  5. hello everyone my first post and question?
    By kingcoota in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-20-2010, 11:51 PM
