Results 1 to 10 of 22
Thread: Last straw...a Frog lives in there!
    Jun 2012
    Texas
    Default Re: Last straw...a Frog lives in there!
    If a frog any bigger than the one I have was in there, I would have passed out! Seriously, I do NOT do frogs!
    Thanks for the vote of confidence. It helps to hear I am on the correct path.
    I am measuring CYA by doing the half tap water, half pool water thing. Like this, the dot is disappearing at 80.
    I am not running the filter 24/7, should I be? The water is a cloudy, light green. The algae that accumulates on the bottom is a brownish-yellow color. I am brushing the pool at least once a day. Is all this rain we are getting going to mess me up even more?
    Do I add more chlorine now? Do I test chlorine everyday? After all the reading I have done, I feel like I understand CYA and chlorine and the relationship now...but I do not understand the "combined chlorine". What does that mean and what level should it be reading?
    Quote Originally Posted by kcoussou View Post
    I'm going to have to tell Watermom that her long lost cousin is posting here. (Watermom is pretty much in your camp; my family tends to consider frogs and snakes part of the fun)
    CYA=160
    Yes.
    Add more chlorine. With a CYA = 160 ppm, you need to keep the chlorine level above 50 ppm, till the algae is gone
    It will, if you don't continue to add chlorine. It will HELP, if you take advantage of the cloudy weather, to raise your chlorine level without losing chlorine to sunlight. I'd recommend adding enough to reach 80 ppm, as soon as you can. That's about 35 gallons of 6% bleach, or about 25 lbs of undiluted calcium hypochlorite. However, cal hypo will raise both your alkalinity and your calcium hardness, and that may not be a good idea.
    No. If you get to 80 ppm, you can wait a day. (Once your pool is clear, you may be able to test only 1x per week.)
    It's chlorine that has reacted with dirt, and formed the chemical equivalent of 'smoke' -- incompletely burned (or oxidized) dirt. Don't worry abou that too much, yet.
    The problem with very high CYA levels is that it takes very high chlorine levels to kill established algae. 80 ppm *should* take care of your problem, but I would recommend ordering some sodium bromide, in case it does not. Adding sodium bromide creates an UNstabilized halogen level that can kill the algae, but at the cost of increased chlorine consumption for several weeks after. Order, but do NOT use it, till you've tried the 80 ppm. Here's the link:
    Nava Chemicals 652072097 Yellow Algae Remover, 2-Pound Bottle @ Amazon
    Tropi Clear TC-4402-1 2-Pound Yellow Eliminator @ Amazon
    Be VERY careful, if you try to buy it elsewhere. There are multiple version of granular "yellow algae" treatments. Some contain sodium bromide; some contain ammonium chlorine, which is completely different and not desirable; some contain bromide PLUS phosphates.
    Just wanted to add -- there's no reason why your kids can't swim now.
    Just tell them to keep their eyes closed and wear old swimsuits. People are FAR more chlorine resistant than women's swimwear -- dermatologists uses 50 ppm (with ZERO stabilizer -- VERY different) bleach baths to treat even pediatric patients. However, 80 ppm of free chlorine will be irritating to eyes, if not as irritating as even low combined chlorine levels.
    And, one more note. It came up in the private support team section that I didn't warn you that high chlorine may lighten your liner. It is possible that that will happen.
    In cases like yours, there is not a perfect answer I can think of:
    1. Super high free chlorine offers some risk of liner bleaching, and definite risk of swimsuit bleaching, and can leave lingering very high chlorine levels which is hard on fashion swimwear.
    2. Unstabilized halogen residual, via sodium bromide, can led to high to very high chlorine consumption in the weeks following.
    3. Use of ammonium chloride (Yellow Out) would require letting your chlorine drop (and the problem get worse!) before starting treatment, and will render the pool unusable for a week or more, with lingering irritant chloramine residuals. (Been there; done that; had the pool user complaints!) Unlike free chlorine, monochloramine sensitization does seem to occur, and apparently results in some pretty severe effects, even at drinking water levels of MC.
    4. Drain and refill, which can damage your liner, and force you to get a new one
    Supplemental algaecides aren't really compatible with chlorine levels like this.
    Hey, Kcoussou---- Ben knows me well. I'm with you on the frog thing! I do not want to be swimming in a pool where there are critters of any sort. (Not even Kermit the frog!)
    Jun 2012
    Texas
    Thanks for all the help here! I am thankful!!
    I just added 35 gallons of 6% bleach at 10pm. Should I test the chlorine level in the morning? Should I vacuum or brush it? Do I get a sample to test before or after I brush it?
    Jun 2012
    Texas
    Good news!! Frogs are dead!! (that is plural, because apparently my nemesis from yesterday had a smaller friend)
    And the pool is blue, cloudy but blue nonetheless!
    I needed to lower the water from more rain last night, so I vacuumed to waste the algae clumps that I found until the water level was where I needed it to be. (trying to take advantage of the free water) Then I regular vacuumed all the sides and bottom.
    Checked the chlorine levels. FC is 83 and CC is like 0.5. It looks like I am on the correct path, but I am still a little confused at the CC level. Seems to me like it would be higher since something is obviously working.
    So, I am thinking that all I do now is check chlorine levels, sweep, filter 24/7 and wait?
    The CC comes down as a result of the chlorine killing off whatever it's fighting, and by exposure to sunlight. So it's normal for it to be coming down--that's a good thing!!
    And you've got it--filter, check chlorine, sweep, and filter some more.....
