Results 11 to 20 of 21
Thread: Pool Calculator; useful?
    Mar 2012
    Tennessee
    Default Re: Pool Calculator; useful?
    I started using the pool calculator this season. So far, so good. Have found it to be very helpful. Able to keep all levels where they should be. Pool is crystal clear.
    1 1/2hp Emerson 2speed pump, BBB
    27' round 19.3K gal AG Vinyl Liner pool; sand filter; pump: 24 hrs on low; Taylor K-2006 FAS-DPD Chlorine; utility water ; PF:6.9
    Virginia
    Quote Originally Posted by Shifty View Post
    Jim,
    I don't think waterbear is telling you not to use the pool calculator, rather saying "proceed with caution." If you can reasonably estimate the volume of your pool (there is an estimating tool at the bottom of the calculator) and you know how the different chemicals react with one another (i.e. trichlor raises CYA and chlorine, but is acidic and lowers pH), it is a useful tool to use. I find myself mainly using the pool calculator for doses of bleach and borax.
    Quote Originally Posted by AnnaK View Post
    I second what shifty wrote. I can't use the bleachcalc because it's a Windows executable and I run a Mac. The Pool Calc is HTML based and runs on any platform. Like you, I use it for bleach and Borax calculations and occasionally for "effects of adding xyz". It has never lead me wrong but I now have enough experience with my particular pool to know when I should question any results obtained. The caveat I follow is "add half now, test, add more later".
    Quote Originally Posted by tnalaskan View Post
    Thanks. I appreciate the clarification and feedback.
    Some use it and swear by it. I never do.
    I figure 1 gallon of <n>% bleach in 10,000 gallons of water raises FC by <n>ppm. It's a convenient rule of thumb based on the actual formula: (1,000,000/pool vol) * (bleach concentration) * (amount of bleach) = FC increase.
    Virginia
    For those of us who are more mathmatically challenged, could you give an example (perhaps using my 20k gal pool using 6% bleach)?
    Thanks.
    In 10,000 gallons of water, a gallon of 6% bleach would add 6ppm of chlorine. So, since you have twice as much water, in your pool, it would add only half that much which would be 3ppm of chlorine.
  6. #16
    Lehigh Valley, PA
    Figuring bleach is pretty easy, but how do you calculate borax or baking soda? I'm one of the mathematically challenged.
  7. #17
    Virginia
    Thanks. I wasn't clear about parts of the equation, such as the units for the amount of bleach (ounces? gallons?) and the part about concentration (for 6% bleach, would I multiply by 6? or 6%?), but your example clears it up.
  8. #18
    Anna, I never calculate borax and baking soda. I just make a judgement on how much to add and do small increments until the target is reached. There are so many variables that affect pH and TA that it is kinda hard to have an exact formula for them.
  9. #19
    Lehigh Valley, PA
    For pH, I agree, but alkalinity is pretty straight forward.
  10. #20
    Jul 2012
    Cincinnati, OH
    Watermom.....thanks for the link...that will be a big help getting me started on BBB!!!
    18x40 Lazy L 30K gal IG Vinyl pool; tri-clor feeder; Hayward #250 sand sand filter; Hayward super-1-1/2 HP pump; ; Taylor 2006c; utility water- PF:4
  1. The Pool Calculator
    By Scetnk in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-25-2011, 02:17 PM
  2. The BBB System and Pool Calculator
    By thorn138 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2011, 12:13 AM
  3. Kiddie Pool Calculator has an error.
    By grammy in forum General Interest
    Last Post: 07-08-2011, 11:54 PM
  4. pool calculator question?
    By anikahmae in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-16-2011, 07:24 PM
  5. Pool Calculator
    By pedsrn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-17-2010, 07:49 PM
