Page 6 of 8 FirstFirst ... 4 5 6 7 8 LastLast
Results 51 to 60 of 74
Thread: First Time using Taylor HELP!!!!!!!!!!!!!!
  1. #51
    mroll is offline Subscriber Thread Analyst mroll 0
    Jun 2012
    Long Island, NY
    Default Re: First Time using Taylor HELP!!!!!!!!!!!!!!
    If your CYA is 65, then it's time to stop using the dichlor and switch to bleach. It's also time for you to keep a minimum of 5 ppm of chlorine in the pool at all times. Sometimes it just takes a few days for it to register. You've been using a lot of dichlor, so I'm not surprised it's risen a bit. If your pH is below 7.0, dose it with Borax to bring it back up to the 7.2-7.6 range.
    Relax--it's just a pool!!
    Silly getting stressed over a pool, right???
    BUT I rather have a CYA of 30-40 and only need FC of 3-4....
    How much bleach?
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar; winter: Not bought yet; ; PF:21??
  2. #52
    "In your pool, a quart of 6% bleach will add around 2.5ppm of chlorine.". Test your chlorine with your kit, and add whatever amount is needed to get back over 5 ppm, using that statement as a guide.
    Jun 2012
    Long Island, NY
    Unfortunately my DPD powder is almost all gone..did not last long,,Leaving on vacation in a week and son will be testing, hopefully with regular kit. According to Dave, he should put in about 4 cups bleach to keep it over 3. Is all this still right with CYA so high??? I think I will test that again Wednesday night. Could CYA go down by itself???
    Oh gee this is getting too complicated.............waaaa
  4. #54
    I think you're making this harder than it really is...all your son should do is test the water, see what the result is, and then add bleach to get it back over 5 ppm. If he needs to add 1 ppm, he should add 2 cups. If he needs to add 2 ppm, he should add about 4 cups. If he needs to add 3 ppm, he needs to add about 6 cups. These are estimates, but they will work to make it as simple as possible.
    If you stop using dichlor, your CYA will eventually decrease via splashout or water lost during filter cleanings--but it's going to be slow. Plan on keeping 5 ppm of chlorine in the pool for awhile...
    Jun 2012
    Long Island, NY
    Redid CYA with same water and solution..looks like 50 now which would make more sense. Again, will only be able to test with DPD powder for another 2 or 3 days..Will order more..BUT With regular test , ONLY REGISTERS UP TO 3 ppm. So what do we do???
  6. #56
    Here's how to force it to read higher...
    http://www.poolsolutions.com/gd/how-...d-testkit.html
    Jun 2012
    Long Island, NY
    My DPD test will arrive Thursday but my son will only be using the OTO if he remembers. I am retesting everything tomorrow night and will repost the numbers so I can finalize my plans.. Tonight put in 3 cups bleach only
  8. #58
    BigDave's Avatar
    What were your FC, CC, and last night? What day are you leaving?
  9. #59
    Jun 2012
    Long Island, NY
    Only did OTO test last night. (3+) Will do it all tonight around 5:30 -6 and post. Leaving Thursday. Thanks for getting back to me Dave.
    M
  10. #60
    BigDave's Avatar
    Please also do pH. 3+ OTO is what I'd like to see. We can run the recipie for your son for a couple days and see how it goes. Thanks.
  1. Long Time Lurker, First Time Poster
    By MikeD in forum Dealing with Algae & Slime
    Last Post: 08-04-2012, 09:26 AM
  2. Long time reader, first time author
    By j_stewart89 in forum General Interest
    Last Post: 04-06-2012, 07:05 PM
  3. taylor- 2005 vs taylor-2006
    By axell in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-11-2012, 11:05 PM
  4. Just got my Taylor
    By Dooley11 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-04-2011, 12:03 AM
  5. taylor dpd #2
    By dhale63 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2007, 01:44 PM
