I know there is a lot of variables, but on average with normal operation and assuming you keep ahead of the pool with a residual, how often do you shock?
When CC gets above .5
I do put a little extra bleach in the pool right after a heavy bather load though, but not up to "shock" levels.
Sherra
Kershaw County South Carolina
18x34 IG 2' radius rectangle vinyl liner (approx 27,500 gal) 1 1/2" pipes installed March 2006
(previous AG pool owner)
Usually 3 times a year. About a six month operating season.
Typically:
Opening
Pre or Post vacation
Closing
+ If some unusual biological event comes up, like a large child swimmer load, dead animal etc.
I did not shock on opening this year because I opened it early due to 80 degree weather in early April.
I only shock if I have CC. I haven't had any CC in over a year, so I haven't shocked.
Michael
You and your SWG don't count.Originally Posted by mwsmith2
Well, technically aren't you shocking continuously?
I never shock unless CC gets up.
Yup, that is true. The Cl levels in the cell are high enough to acheive breakpoint. but, the same still holds true: if I don't have any CCs I don't shock. My pool doesn't turn green, so no reason there. If I get mustard, high Cl won't help it (been there, done that) so out comes the polyquat.Originally Posted by Rangeball
However, when using bleach, I usually hovered around 0.5 CC. Never bothered to shock to get rid of it. Tried once and it seems I didn't go high enough, so it stayed the same.
Michael
Only when the cc gets above .5 (hasn't in the last two years)(indoor pool) or if a child has a "poop" accident. I do double dose after a kids swim part to make sure but usually not above about 4ppm.
I 'shocked' once last season, and haven't yet this year. Of course, using just bleach for chlorination.
CaryB
Go 'Canes...advancing to the Stanley Cup Finals!!
Hope its not inappropriate to ask this in this thread. I know you shock to get rid of CC and bather waste, but is it just "pool store hype" that you should shock every week? It really threw me for a loop to find how little you guys shock.
John
