Re: CYA Levels Okay at Minimum?
You did very well--congratulations for not letting them "pool-store" you!!!
We recommend that most people start out with a CYA of 20-40 ppm, which require that you maintain your chlorine levels at 3-6 ppm of chlorine. If you find that you lose chlorine too quickly, like Waterbear said, you can always bump it up a little if you need to!
