Results 1 to 10 of 24
Thread: biologically sourced metal
    Default Re: biologically sourced metal
    Quote Originally Posted by mbar View Post
    I was shocked, but I added it to my "things that night work" list
    the wife: "Think it'll work?"
    Miracle Max: "It'll take a miracle!"
    Yeah, but I'd be like Purplegirl. I'd want my water to be pretty like everybody else's. Yeah, they can swim, but..... how disappointing to want a sparkling blue pool and have to be satisfied with green water.
    Purplegirl, you're being a real trooper with your attitude about this. I'm afraid I wouldn't be handling it as well as you are. I would be totally and I mean TOTALLY bummed out.
    Well, have fun swimming anyways!
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Since your pool is only 5,000 gallons, you could probably get water delivered that wasn't green? That would probably only be temporary as you have to add water over time to compensate for splash out and evaperation... At least you'd have 'blue' water for a while...
    I personally think the decorator water idea from Waterbear is a good one! Hey, it might even catch on and you could market/sell it
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    You could also tell eveyone that your liner is chartreuse!
    Jun 2010
    new york
    Watermom I AM totally bummed out but I'm starting to accept the situation and I'm crossing my fingers that it will eventually precipitate out. Pool Doc is right my kids don't care it's just me and my husband that are hung up on green water
    From what I've read here, there is usually a solution to any pool problem and I feel so defeated that I can't fix my pool problem.
    sturev I thought about ordering water but I didn't have much luck locating a company (I didn't try that hard to find one). It only costs me about $20 from the tap I can't even imagine what they charge to deliver. Plus one pool store told me (I know I shouldn't even listen to them) that shipped water comes from a well and I will have metal problems from that water as well. I don't know if that's true?
    Marie, how much calcium are we talking here? I don't know anything about calcium, I have an Intex filter would adding calcium cloud the water or anything? Would there be any negatives to trying calcium? I'm willing to try anything as long as it doesn't give me another problem.
    BTW I think I might be having a problem with my FC, I will post numbers tomorrow morning.
    mbar's Avatar
    Ashland, PA
    Not much calcium. I put enough in my pool to take it to about 125 to 150 ppms when the water turned blue. I have no explanation, I just watched it do it. The water was tinged a slight green and I thought I was going to do the stain treatment so I wasn't too worried about it. Five minutes after putting the calcium in the water turned blue. I hesitated to say anything about it cause it just may have been a fluke, but I thought I would mention it because you really hate your water being green As Kermit would say "It's not easy being green"
    Northeast PA
    Marie, purplegirl, be sure to email or PM me if the calcium helps. [ poolforum AT gmail DOT com ] I'd like to know, and I'll be sure to pass it on to Richard (Chem Geek).
    Of course, if it does work, it will probably keep him up at night, till he can think of a possible analytical explanation for 'why' and 'how'. Me, not quite so much, but I'd still like to know.
    PoolDoc
