Confused yet, purplegirl?
I wonder if the weights make a difference when she adds them to her green pool that's filled with iron?Gotta be heavier!
Evan S.
AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
sturev are you making fun of my green pool
I would probably be confused AnnaK if I didn't have a scale, but since I do I'm not going to worry about all the rest, I'll just weigh everything out.
But thanks to everyone for the info. I never realized having a pool was so much work![]()
Your pool won't always be so much work. Once you have done this for awhile, it will become routine and will be easy. I typically spend less than 5 minutes each day on my pool. That is it. (Other than throwing in the Wanda the Whale vacuum a couple of times per week. But, then she does the work, not me!)
'Mom is right (she is pretty much 99.99% of the time). None of the mods spends a great deal of time maintaining our pools--nor do most of our members (at least the active ones). Our methods are geared to being:
1) Effective
2) Simple
3) Cheap
4) Easy
But you do have to be consistent.
Actually, most of us spend far more time on PF than we do maintaining our own pools!
