Re: Cloudy Pool Water - Could use some help
I'll check the pool throughout the day and continue to try and get this to shock level.
Only problem...I'm out of bleach so I'll need to run out for more sometime today. I know Watermom said not to use the dichlor anymore as it may be contributing to the cloudiness. I have quite a bit of the dichlor on hand........considering my CA is low would it hurt to add a few pounds of the Chlor Brite or should I avoid that for now and stick with bleach? I don't want to mess this up but at the same time I hate to wait until I can get some more bleach (which would probably be a few hours from now.) Wife is going to run to Walmart (which was cleaned out of their brand yesterday) and probably to the Aldi's for their brand as well. Will also hit the BJ's club tonight and see if I can buy in bulk.
-Brian
