Results 1 to 10 of 61
Thread: Cloudy Pool Water - Could use some help
    Default Re: Cloudy Pool Water - Could use some help
    Check in with us every once in awhile and let us know that you haven't filled the pool in with dirt!
    (It may take awhile .............hang in there!)
    May 2010
    Northeast PA - USA
    At 8pm tonight I checked the water again and it's still cloudy. Here's the CL levels:
    FC = .8 ppm
    CC = .6 ppm (big difference from earlier today for some reason)
    I added (2) 182oz bottles of 6% bleach at about 8pm as well.
    I also checked the PH and it was really low so I started adding the Borax by the cup into the skimmer. I'll have to check the guidelines on how much to add as I've been so busy trying to handle the chlorine levels that now I have to learn to also balance the PH (and the other levels.)
    I plan to check the CL levels again tonight between 10-11pm and possibly add bleach one more time before bed. I'll also let the pump run all night again and cross my fingers for the morning.
    I don't plan to fill the pool in with dirt just yet although I think it crossed my wife's mind. She definitely has issues with buying so much bleach as she thinks people are looking at her like she has two heads. I keep assuring her that our patience (and lots of bleach) will pay off shortly.
    Have a great night and I'll continue to check in tomorrow.
    May 2010
    Northeast PA - USA
    I checked the water tonight and here are the levels:
    FC = 4.8 ppm
    CC = .4 ppm
    pH = < 7.0 (I had to add 6 drops of base to bring the pH back to the 7.2-7.4 level)
    I just added (2) more 182oz bottles of bleach and the rest of the box (76oz) of Borax to see if I could bring the pH back up. We'll see what the night does for me and hope for the best in the morning.
    Get the pH up above 7.0 ASAP! Below that is acidic and can damage your pool. That is actually more critical than the cl issue right now.
    I'll look for your current numbers in the morning. At least your CC isn't still showing up as 11!
    Yes, I'd add at least half a box of Borax to start, then wait an hour and check pH again, and repeat until you get a reading over 7.
    May 2010
    Northeast PA - USA
    Good Morning.
    Tested the water again today at 8am. Here are the results:
    FC = 4.4 ppm
    CC = .2 ppm
    pH = 6.9 (6-drops to get to 7.4)
    I just added the following to the pool:
    (1) 96oz bottle of bleach
    Approx 2lbs Soda Ash
    Hoping the bleach will help get me to shock level which I've had a tough time reaching. And the Soda Ash (which was used instead of Borax since I have no more in stock) will hopefully help bring up the pH. The water is still cloudy though.
    Gotta take another run to the store today. Need more Borax and the three cases of bleach I bought last night at BJ's are in the pool already! I have about 6-7 bottles of the 96oz bleach so that should keep me going for a bit.
    At this point, I'm REALLY looking forward to getting the water chemistry balanced!
