Results 1 to 10 of 61
Thread: Cloudy Pool Water - Could use some help
    Default Re: Cloudy Pool Water - Could use some help
    CC still 0! That is a good thing. How is the water clarity? Any improvement today? Go ahead and add some bleach tonight to take it up to about 12-15. Hopefully, it will all still be there in the morning and the CC will still be 0.
    Watch your filter pressure since you added DE. You only want a 1psi rise in pressure.
    May 2010
    Northeast PA - USA
    Hi.....I can definitely see the bottom of the pool, just not that 'sparkling' clear water that we're all looking for. I would call it 'dull' at best.
    I'll add another 182oz jug of bleach now and let the filter run overnight. We'll see how that works.
    Thanks for the hand-holding. I appreciate it.
    May 2010
    Northeast PA - USA
    As of 11pm here are my cl levels:
    FC = 17.2 ppm
    CC = 0
    We'll see what they look like in the morning. Have a good evening!
    May 2010
    Northeast PA - USA
    As of 8:30am here are my cl levels:
    FC = 11.0 ppm
    CC = 0
    pH = 7.2
    Water seems to be VERY slowly getting clearer, but again very hard to tell. Still very dull. Unsure why I would lose so much cl overnight though.
    I'll be gone most of the morning and early afternoon with family but will check the levels later when I get home.
    Happy 4th of July everyone!!
    Go ahead and add more bleach this morning. I was hoping you wouldn't have chlorine loss overnight. Darn. Don't forget to check filter pressure. Have a good day with your family.
    mbar's Avatar
    Ashland, PA
    Watermom, I will go along with you on this, because you know more than I do about pools, but I thought as long as you don't have cc then it is ok to swim. I was thinking the chlorine loss was due to the chlorine breaking down the dead stuff (watermold) so it could be filtered out. I know when I was fighting watermold the water took a while to clear, and it used up mega doses of chlorine. It took almost a week for the water to get back to it's regular sparkly clean look. I am very interested in you answer, thanks
    Northeast PA
