In a dry area, you most likely have a low water table which is good when it comes to draining pools. You shouldn't have any problems. I assume you have a bottom drain. Not sure about the pressure washer. I'm gonna let someone else answer that part of your question for you. Probably ok as long as not the highest pressure but see who else chimes in on that.
