Re: Backwashing and shocking
Hi everyone! I'm new to The PoolForum so if my post is out of place, please feel free to move it.
We are having an issue with backwashing and shocking our pool it that we have done it more to our new pool installed four months ago, than we ever did with our old above ground pool. It involves an algae issue but after reading the posts in the algae forum, I decided to post here because in the last 15 years we've had above ground pools, we have primarily use a shock product - and an occasional clarifier product... and never checked any water levels! I vacuumed the pool every other day and my husband backwashed every other week or so. We never had any problems like this before.
I am vacuuming the pool AT LEAST once a day, in the morning, and before the sun sets, the bottom of the pool is covered with a fine green/brown dusting as described in the algae forum. And I have to backwash AT LEAST TWICE before I finish vacuuming!
We will try the DE and filter sock (if I can find one) and I will attempt to find a water tester so I can provide you with the levels. Meanwhile, I need to find some kind of primer on pool maintenance and what all the abbreviations mean and how to deal with each.
Meanwhile, can you tell me if I'm destroying our filter by backwashing so much? (The Doughboy documents are very sparse)
Thanks for your time!
Judi McRae - Katy, TX
Doughboy Sand Dollar II 18' x 48" Vinyl liner - ~ 7,000 gal
Pool Power Pak II pump - Media Master 1600 sand filter
