Re: Pool Help, Please!
Do you know what chemicals you've put into the pool? Not product names, but the chemicals themselves...
You really need your own test kit to care for your pool. It will pay for itself 100 times over! Since you can only buy the Taylor K-2006 online and it takes a few days to show up, go to Walmart asap and you can buy a temporary kit to use until the Taylor one is delivered. I believe they have 5 or 6 way kits for under $20 or so. You can use the 'shot glass' method to test high levels of Chlorine with the Walmart kit. Search for 'shot glass' and you can find the post that tells you how. Post the test results and what you've put in the pool and someone will help you.
Evan S.
AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
