Results 1 to 10 of 11
Thread: PH/chlorine levels out of whack already:(
    Default Re: PH/chlorine levels out of whack already:(
    What is the volume of the pool? If this is a new fill and you have little cya in there, chlorine doesn't stick around long. How many times a day are you testing and adding dichlor?
    Jun 2010
    British Columbia, Canada
    The pool holds a little over 1700 gal. I have been testing once a day and adding 1 TBSP dichlor each day. Missed testing yesterday. My little guy had to go for stiches
    As I mentioned above, until you have a measurable cya reading, you will lose chlorine fast in the pool. Adding 1 TBSP dichlor will raise the cl level in your pool by 1ppm. That isn't much and then without much cya yet, the cl will be gone quickly. I think for the first week or so you should probably be adding dichlor probably 3 times a day. Or maybe add more than 1 TBSP at a time. Maybe try adding 4 TBSP in the morning and see if that amount will allow you to keep from dropping below 1ppm by evening. Either way, the bottom line is you are not putting enough chlorine in the pool each day and that is why your FC seems to be at 0. You are risking an algae bloom by having this happen.
    In regards to pH, dichlor is pretty acidic so it will drop the pH. You'll just need to test it several times per day and be ready to add Borax any time it drops below 7.2.
    Hope this helps.
    EDIT: One other thing --- 1 lb. dichlor should take your cya up to about 40ppm, so by the time the full pound has been added, you'll need to be keeping your FC between 3-6 all the time to keep algae at bay. For the first week or so, make sure the FC doesn't drop below 1. But, as you use the dichlor, gradually increase your minimum FC level. Maybe next week don't let it drop below 2 and then as you get closer to using the whole pound, don't let it drop below 3ppm.
    Jun 2010
    Just a general idea of how much borax to add?
    You can use The Pool Calculator to get a rough idea for dosages. When adjusting pH, it's only approximate. Be sure to put in your pool volume.
    I think I would probably go with 1/4 cup Borax. Try to get it in there tonight if you can. Retest in the morning and add a little more to tweak it a bit if needed.
    Jun 2010
    Hi,
    I added 1/4 c borax last night and 1/2 cup this a.m. Brought my PH up to 7.4.
    Upon testing for FC 25 ml sample turned pink upon adding 1 scoop. After 16 drops of
    R-0871 still could not get to go colorless. I gave up! Is this normal and what do you do at that point? Other numbers were:
    TA- 50ppm
    CH 40ppm
    CYA-Black dot never did go away... Maybe I did not let sample sit long enough. Did not appear to very cloudy either. I am not sure if I have enough CYA in the water at this point to register.
    I am thinking about adding 1-2 TBSP baking soda to bring up TA.
    Use a 10 ml sample when testing chlorine. You don't need the .2 ppm resolution that the 25 ml sample gives. .5 ppm resolution is more than enough!
    You will use a lot more reagent
    16 drops with a 25 ml sample is only 3.2ppm FC I would not worry about the TA or CH at this point.
    Just concentrate on getting enough CYA and keeping the pH between 7.2 and 7.8.
    Once you have enough CYA and switch to bleach we can worry about the rest of the water balance if there is a need to. There very well might not be!
