Results 1 to 10 of 16
Thread: How much bleach?
    Default Re: How much bleach?
    Your numbers are FINE!
    Little Intex donuts can be a lot of fun--We had a 15' for 3 years.
    Now you can start using bleach to chlorinate your pool, which is really, really cheap and effective.
    One quart of regular 6% bleach will add almost 9ppm of chlorine to your pool. I suggest before you leave you add that quart to raise it near-shock level, cover it (the Intexes usually come with a cover) and don't worry!
    One pint of bleach will add 4.4ppm of chlorine to your pool. The Di-Chlor has done its job. You have a nice CYA level, your pH is good, and the bleach won't affect either. Plus you can get it anywhere!
    Jun 2010
    British Columbia, Canada
    Will it matter if my filter is running or not?
    I would make sure and run it for at least 2 hours after your bleach addition, and then you can shut it off it you want to, especially if you're covering it. If it's only for a couple of days, then you shouldn't have any problem at all--and even if you do, the fix is pretty easy!
    I had an inexpensive plug-in outdoor timer I used on my Intex. I think it was about $40 or $50 and it hung on the wall next to the outdoor outlet, designed for outdoors. I'd run the pool 8-10 hours/day.
    My friends down the street have the same type of timer on theirs, but their pool is under a big oak tree with lots of big leaves that clog the skimmer. Running the pool while you're home is obviously a necessity, but while you're gone, you'll have to make the decision as to whether you can safely run it without plugging up the skimmer with leaves, etc. or not. As I mentioned in my post above, if it's too risky, then it would be okay for a couple of days without running. If it's not a danger, then by all means run it via timer!
    Jun 2010
    Talking Re: How much bleach?
    Hi,
    I am back!! This afternoon we returned home to a very clear pool! YEAH!!!!!
    Here are my numbers:
    PH 7.4 -7.5 Very close
    FC 8.5
    CC 0.5
    TA 130
    I did as was recommended and added 1 gallon of bleach and let the filter run for 3 hours prior to leaving and then covered.
    Do I need to do anything at this point to bring down my FC and CC? Not sure how to do that...
    Thank you again for the advise. I am so glad I found this great group of people. I honestly did not think of the pool one time while away. I just had enough faith in what I have been told thus far and I will continue to swear by the BBB method!
    By the way... I love my test kit. I feel like it is so accurate and takes away all of the GUESS work
    Carrie
    Last edited by drako4; 07-12-2010 at 11:54 AM. Reason: amended amount of bleach to one quart. Not a gallon.
    The FC will come down on its own. If someone has a CC level above 0.5, we recommend shocking the pool. If it is 0.5 or below, you are ok ------ although, if you want to shock the pool to get the CC down to 0 that is fine, too. Glad it was clear when you got home!
