I had an inexpensive plug-in outdoor timer I used on my Intex. I think it was about $40 or $50 and it hung on the wall next to the outdoor outlet, designed for outdoors. I'd run the pool 8-10 hours/day.
My friends down the street have the same type of timer on theirs, but their pool is under a big oak tree with lots of big leaves that clog the skimmer. Running the pool while you're home is obviously a necessity, but while you're gone, you'll have to make the decision as to whether you can safely run it without plugging up the skimmer with leaves, etc. or not. As I mentioned in my post above, if it's too risky, then it would be okay for a couple of days without running. If it's not a danger, then by all means run it via timer!
Hi,
I am back!! This afternoon we returned home to a very clear pool! YEAH!!!!!
Here are my numbers:
PH 7.4 -7.5 Very close
FC 8.5
CC 0.5
TA 130
I did as was recommended and added 1 gallon of bleach and let the filter run for 3 hours prior to leaving and then covered.
Do I need to do anything at this point to bring down my FC and CC? Not sure how to do that...
Thank you again for the advise. I am so glad I found this great group of people. I honestly did not think of the pool one time while away. I just had enough faith in what I have been told thus far and I will continue to swear by the BBB method!
By the way... I love my test kit. I feel like it is so accurate and takes away all of the GUESS work
Carrie
Last edited by drako4; 07-12-2010 at 11:54 AM. Reason: amended amount of bleach to one quart. Not a gallon.
The FC will come down on its own. If someone has a CC level above 0.5, we recommend shocking the pool. If it is 0.5 or below, you are ok ------ although, if you want to shock the pool to get the CC down to 0 that is fine, too. Glad it was clear when you got home!
If I decide to shock the pool, approx. how much bleach should I put in? As the FC comes down on its own, will the CC as well?
Do I need to test my CYA again at some point?
Cheers![]()
In your pool, 1/4 of a cup of 6% bleach will raise your cl by 1ppm. With a cya of 40, you should keep your cl between 3-6 all the time and your shock level will be 15. CC will NOT come down as FC does.
Have you used anything besides the dichlor to raise the cya? If not, I wouldn't worry about testing for it again for quite awhile. Maybe sometime in another month or so and maybe in the fall when you get ready to close the pool. The people who have to test for it frequently are those who are using trichlor tabs and dichlor powder to shock with.
I'm willing to bet that if you'll just leave the pool uncovered for awhile during the day, that CC will disappear without shocking the pool. Otherwise, your numbers look great, so I would test it again before shocking. Of course, it never HURTS to shock, but no need to expend the bleach if you don't need to.
Up to you.........
I have not used anything other dichlor to bring up CYA.. I was going to just uncover and see what happened for today, but, we now have a forecast of rainshowers all day.
Might be a silly question but here goes anyway.. If I uncover will the rain change any of my readings. I am not sure how rain really effects a pool. Should I leave covered?
Cheers
Carrie
