Results 1 to 10 of 16
Thread: How much bleach?
    Default Re: How much bleach?
    The rain probably will dilute your chlorine, albeit only a little--unless it's a storm with lots of wind that would blow debris into your pool. It shouldn't affect any of the other readings. So whether to cover it or not is up to you--do you need the water replenishment, or do you need to keep debris from blowing into the pool? If it's just passing rain showers, I'd leave it uncovered, but that's just my opinion.
    Lehigh Valley, PA
    Very heavy rain may increase your pH some. The splashing and splattering acts to aerate the pool much like a fountain does. Covering it would prevent that, of course.
    Have you ever calculated how much water you add by raising the level of your pool by 1"? It's a useful calculation to do because you'll know how many extra gallons have been added to your pool by that 1 inch, and you can use the pool calculator to figure the effect of adding chemicals to the new volume. It also tells you whether a rainfall of 1/2", 1", 4" will make a difference and what difference it may make in the dilutions.
    Jun 2010
    British Columbia, Canada
    Unhappy Re: How much bleach?
    Hello,
    Well the day after returning home I decided to shock since my FC was 5.5 and CC=0.5.
    I did leave the pool uncovered but cc did not go away. I added 1 quart of bleach that evening and took the FC up to about 15. I left it uncovered.
    My CC did go to 0 the following morning.
    Upon testing this evening though, my FC is 5.5 and CC is back up to 0.5. There has been no swimming. Just wondering why the CC is up again. I know I was told that it was not necessary to shock with a CC of 0.5 or less. I was worried it might get away on me so decided to shock the pool. However, to do it again would probably have the same outcome??
    Any ideas on what I should do or just leave it at this point. My PH is currently 7.4.
    Prior to leaving My CC was consistently 0.
    As always. Thanks!
