Results 1 to 10 of 17
Thread: It's BAAACK!!!
    Default Re: It's BAAACK!!!
    I do remember your username and remember that I helped you before, but I work on so many different threads and with so many different members/pools that I cannot remember the specifics about your situation.
    If you let the FC drop to 0, then you invite algae. You will need to go back to running your pool at shock level (based on your cya level) and try and hold it there to get rid of the algae. Run the pump 24/7, brush the walls and floor of the pool. Test and add chlorine as many times a day as you can and each time take it back to shock level. Take it up to shock level this evening. Test again early in the a.m. When you can go two days with no more than 1ppm of cl loss overnight, you can let it drift back down and then do not ever let your cl drop below 5. It may take awhile to filter out dead algae if that is what is causing the cloudiness. Repost with a full set of current water testing results when you have had two mornings in a row with no more than 1ppm of cl loss and tell us how the water looks at that time.
    Also, if you have brown stuff settling on the bottom, can you slowly (so as to not get it back in suspension) vacuum to waste and get it out of the pool?
    Sue225 is offline Subscriber Thread Analyst Sue225 0
    Jun 2010
    NW Indiana
    The pool was at 25ppm chlorine and my husband misunderstood me and added 2 gal of 12%. The chlorine is so high i can't measure it. I was up to 100 drops of 0871 with taylor kit and still water was orangy looking. Will all this chlorine burn off?
    Jun 2010
    NW Indiana
    yes it is. Liner is alread in sorry shape puckering from unbalanced water since last summer. pool is 23 years old. We will either replace liner or new pool next summer if we don't blow it up before then!!
    It may take a day or two, but the chlorine will come down on its own. The up side is that you now have a well-shocked pool!
    Jun 2010
    NW Indiana
    Ph is higher than 8
    CC 0
    fc 26 after sun was on it for a couple hours.
    with cya of 80 i will leeft pool drift down to 20ppm and hold it there for 24 more hours. What do you think?
    I am vacuuming to waste, by passing filter
    will keep you posted about algae
    The pH may be reading falsely high because your chlorine level is high, so I wouldn't adjust it until you get the chlorine down closer to normal levels. Let the chlorine drift down to 20 ppm, and leave it there until the pool clears, you're not losing any chlorine overnight, and your CC stays at 0. How's the water looking?
