Results 1 to 10 of 17
Thread: It's BAAACK!!!
    Default Re: It's BAAACK!!!
    If you let it sit, it will always start to tinge pink--ignore it. If you didn't have any pink when you added the 5 drops, then you don't have any CC.
    If the water is holding chlorine overnight, it's clear, and you have no CC, then you can let it start drifting back down to normal--but never less than 5 ppm!! Once it gets below 10 ppm, go ahead and recheck your pH. If it's still high, then you can adjust it at that point.
    Sue225 is offline Subscriber Thread Analyst Sue225 0
    Jun 2010
    NW Indiana
    fc was 10 this evening, cc was 0 and ph 7.5. Added 2 qts of 6%. Can't get out there to check chlorine levels because it is storming. I did add 24 oz of poly... because we are having company and temps will be in 90's. Wanted to make sure the algae was gone!!
    We are still vacuuming to waste. Much less brown areas on bottom of pool. Seems like to chlorine dropped quite a bit after I added poly..algecide. Is this normal?
