Can you post the rest of your readings, like CYA and FC for starters?
Attaching Chem_Geek's papers:
Effect of saline on the eye irritation caused by swimming-pool water, 1973
Fluorophotometric measurement of pH of human tears in vivo, 1997
http://www.ncbi.nlm.nih.gov/pubmed/9154387
Ben
That's 2000 ppm of salt, not a TDS reading?Add salt.
Many pool owners add enough to reach around 2000 ppm and report a increase in bather comfort.
Apologies if I am re-treading old ground. When I search for TDS, it's to short to be used by the search function.
IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
Heating? Great info on why a solar cover saves $$$?
http://energy.gov/energysaver/articl...ng-pool-covers
In practice, TDS and salt at such higher levels will be very close -- usually the TDS is around 200 ppm higher than the salt level, but this depends a lot on how TDS is measured and usually it isn't measured accurately (since you have to know the components of the water to properly calculate TDS in ppm). So just use a decent salt test and calculate the amount to add based on salt ppm (you can use The Pool Calculator for that).
