Results 1 to 10 of 29
Thread: How often to test & how much chlorine to add daily? Also, vacation upcoming...
    Jun 2010
    South MS
    Default Re: How often to test & how much chlorine to add daily? Also, vacation upcoming...
    We haven't done much testing afterward, but will start doing that now. I did buy 4 large containers of bleach from Walmart today, thinking they probably move a lot more bleach. (Our last bottles were bought from 2 different Dollar General stores.)
    I also bought some polyquat 60%. CarlD, if you are still reading this, how much would you recommend for algae prevention and a week away? Our pool is about 5000 gallons.
    Tricia from South MS
    Intex Above Ground Metal-Framed Pool 15' x 48" (~5000 gallons) installed 6/21/10, and now using BBB (well only one of the B's so far) and Taylor K-2006 test kit
    It will be interesting to see what your actual overnight chlorine loss is--measure tonight and in the morning, and be sure and let us know...
    Jun 2010
    South MS
    Okay, numbers for the evening...
    Last FC reported on this post was 11 ppm at 11:30 this morning (Thursday). We did not add any chlorine at this point.
    At 4 p.m. today DH added 4 quarts of the Dollar General Bleach (tested to only be 3.5%).
    Unfortunately we do not know how much the chlorine had dropped before the bleach was added at 4 p.m. since I wasn't home (stuck in line at Walmart with the whole store full of registers with computers down) and DH did not test at this time.
    At 8 p.m. our FC level was 9.5 ppm. We added 2 quarts of the new bleach (Walmart brand), which should have brought our FC level to 15.5 ppm.
    At 10 p.m. our FC level was 13 ppm. Either the bleach wasn't 6% or something is eating up the bleach.
    We will test in the morning and I will post the results. Then I will probably add a maintenance dose of polyquat 60 to the pool.
    Oh, I forgot to submit this reply when I wrote it about half an hour ago. Since then, we have done the test and verified that our Walmart bleach we just bought today is indeed 6 percent. However, we think the Dollar General bleach may have gotten a bad rap due to measuring mistakes. We used a pipette we had from a microscope set to measure the 1 mL bleach earlier today. However, we just found out that it wasn't accurate at all. I had ordered a set of scientific graduated cylinders (for our homoschool) and we got them today. Using the 10 mL cylinder, we found that what we though had been 1 mL bleach was actually only a bit over half (maybe 0.6 or 0.7 mL). We are retesting the DG bleach now to see what percent it really is. Well, we retested and still got 3.5% for the DG brand.
    Jun 2010
    South MS
    Okay, so at 10 p.m. our FC was 13 ppm (last night). This morning at 7:45 a.m. it was 12 ppm. We only lost 1 ppm last night. This is good, right?
    I think we are going to add the polyquat now.
    yes, that's much, much better!! I would think that today's loss will be less than was reported yesterday, too--but testing won't bear that out because the Polyquat will probably drop your chlorine a bit.
  1. Average daily chlorine loss and CYA
    By jwhouse in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-04-2012, 07:02 PM
  2. Pool being stubborn--green, high pH, no chlorine after daily work--HELP please
    By BethL in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-22-2011, 07:24 PM
  3. What is normal daily chlorine usage?
    By Electrikkoolaid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-17-2011, 03:42 PM
  4. How many PPM of Chlorine should I lose daily?
    By keithw in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-10-2006, 06:06 PM
  5. Using Bleach as daily chlorine
    By golfwig in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2006, 04:29 PM
