Closed Thread
Thread: First result set with Taylor kit, need balancing/clearing help
    May 2010
    Default First result set with Taylor kit, need balancing/clearing help
    Hi all, I've posted previously in the algae section and received great responses. I was able to clear my murky pool but in waiting for my Taylor test kit to arrive it has started to go green on me again. Please take a look at these results and let me know how to proceed:
    FC=0
    pH=7.6
    TA=200
    CH=325
    CYA=70
    Water balance=.575 (using the included wheel)
    I have a 33,000 gallon chlorinated plaster pool and due to high levels of stabilizer have been told that I should just use regular bleach to chlorinate the pool or be forced to empty and refill to reduce stabilizers (which won't happen this summer). How much bleach do I need to add to the pool to get my chlorine to a high level and kill off the algea. I don't know whether to go out and buy 3 or 4 bottles of bleach or 20 or 30. I'll obviously continue to run the pumps and will scrub and vacuum the pool as well. Please help to clean the pool back up.
    Default Re: First result set with Taylor kit, need balancing/clearing help
    Please don't double post. Lets keep all the info about your pool in one place. I'm locking this thread and we'll let people continue to help you in your other thread. Thanks.
Closed Thread
  1. treatment result
    By essikr in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-23-2008, 02:00 AM
  2. Water not clearing up
    By thewayne in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-17-2007, 12:02 PM
  3. Salt in non-SWG pool result observations
    By medvampire in forum The China Shop
    Last Post: 08-09-2006, 03:11 PM
  4. Interesting CC test result
    By donfranko in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-21-2006, 05:10 PM
  5. What to do with test result water?
    By haeffnkr in forum DPD-FAS based testing
    Last Post: 05-30-2006, 11:06 AM
