Re: What kind of algae is this?
I agree with Watermom. I'm guessing your CYA is over 100 and you probably should be keeping your FC at 25--but do NOT move it there until we know the test numbers.
In the meantime, increase your FC to 15ppm and do the following:
1) Continue to brush it everyday.
2) Vacuum to waste everyday--you don't want that stuff in your filter and the more you can physically get out the less you have to chemically deal with.
3) Stop using algaecides. To refine what 'Mom said, there is ONE good algaecide, Polyquat 60%, that's mainly good to prevent algae, not kill it. The other algaecides are going to cause you more problems than you can imagine. In fact, if you've been using an ammonia-based one, it may be helping create the sludge. If so, the good news is chlorine should break that down albeit not as quickly as you'd like.
