New Pool and Need Help Please
We just bought a Chois 14x22 by 52" pool.
The pool is 9,000 gallons.
Can you guys tell me the easiest and best tester kit for me to buy?
Also what do you recommend for chemicals?
If I go with the BBB chemicals what is the amount I will need?
I was told Prestine Blue but am seeing BBB.
So far I bought a large bucket of 3 in 1 at Sams.
I was told to put this in 1st and wait 2 weeks and then do again and wait 2 weeks and then test my water.
I added the dry chemicals through the skimmer.
Was that correct?
We are also going to build a deck around it.
Anyone have any experience building a deck around this type of pool?
What are the best type of steps to put in the pool coming off of a deck?
We were sent a 220 pump instead of the 120.
I ended up just having an electrician come out and wire in the 220 pump.
But I did not know to ask him to put a switch near it. (I thought they had an on/off switch on them). So will have to get that fixed.
Anyone with this type of pool have an enclosure around the pump and sand filter to hide it? Just wondering if that is a good idea.
I am totally dumb to all of this so would appreciate all info.
I am afraid to set foot in a pool store as will end up buying things I don't need.
The ladder that is in the pool now says to weight down with sandbags.
I am reading sandbags create algae.
Can we drill holes in the ladder to make it stay weighted down?
They have straps for the ladder but we have the ladder in a different spot than where the straps are located.
Thanks in advance.
