Results 1 to 10 of 19
Thread: cloudy pool please help
    Default Re: cloudy pool please help
    I assume this is a vinyl pool, and I also assume that you're using trichlor pucks for chlorination? I say this because your CYA is so high and your pH was so low--both side effects of trichlor. Honestly, your CYa level is so high that I'm surprised that you're able to keep the pool algae free at this point. You can do it, by keeping your chlorine above 8 ppm at all times, but if you can, it would be worth draining/refilling abiout 1/2 of your water to get the CYA down to a manageable level.
    On to your question, though--I would try first shocking the pool, using bleach or liquid chlorine. This is going to mean taking the chlorine up to 25 ppm and holding it there by testing/adding more bleach to get back up to 25. You hold it there until 1)the pool starts to clear, 2)you have zero combined chlorine, and 3)you don't lose any chlorine when testing at sundown and again at sunup. If the cloudiness you're seeing is a precursor to an algae bloom, that will take care of it. Keep the filter on 24/7 and clean the cartridge as your pressure indicates. Even if the cloudy isn't impending algae in the water, it never hurts to give the pool a good shocking after a large party.
    What is your calcium hardness level? Do you use any cal-hypo products?
    If shocking the water doesn't help, and it's truly just the backwash from the filter, then you might want to try a flocculant, which is designed to make the little fine particles stick together into bigger particles that can be caught by the filter or sink to the bottom to be vac'd up. I am normally not a proponent of flocs/clarifiers, but this year when I started up my new filter without backwashing the dust off the sand first, a very similar thing happened to me, and it took a bottle of clarifier and a couple of days (and a LOT of vacuuming) to get it cleared up.
    Hope this helps!
    One tweak ----- A clarifier will make small particles clump into bigger particles so the filter can remove them more efficiently. A floc makes these particles clump into much bigger particles that will settle to the bottom of the pool and are then vacummed to waste (not possible with cartridge filters and some DE filters). So, if shocking and holding it at the high cl level for a few days (along with running the pump 24/7 as Jan said) doesn't do the trick, you might try a clarifier, not a floc. (But, I wouldn't be in a hurry to try it. Give the high chlorine and just the filtration system on your pool time to handle it.
    BTW -- It usually isn't a good idea to add a bunch of stuff to try and fix a problem in a pool. Pool stores love to sell you tons of stuff and pool owners who are having trouble are usually quite impatient and frustrated and willing to try anything the pool store suggests. Usually, nothing more than chlorine and patience will solve many problems.
    Welcome to the forum!
    Hi Janet,
    Thanks for your advice. We will shock it today and keep the chlorine level up.
    The calcium hardness level was 160. We don't use any products besides the chlorine. Yes, we have been using the trichlor pucks and have now turned off the chlorinator.
    The pool is actually concrete.
    My husband and I think since we need to get the CYA down anyway that we will just start emptying. I think running a hose into it while it's emptying is counterproductive.
    We did try the flocculent twice over 72 hours and there was no change.
    Appreciate your thoughts.
    Mary
    Good idea doing a partial drain and refill. A lower CYA will make your pool much easier to manage. No more triclor tabs or dichlor shock powder. They are both stabilized and will add CYA. Since this is a concrete pool, once you get the cloudy water cleared up you might want to try using cal-hypo for your source of chlorine for awhile. It is recommnended that concrete pools have a calcium hardness reading between 200-400.
    Hi! and Welcome! You've gotten excellent advice (as usual from Jan and Lisa). I don't have much to add except:
    Personally, I'm biased against flocs and clarifiers. The only one of the latter I like is also the only algaecide we recommend, Polyquat 60%. But I would NOT recommend it if you are going to drain and refill until after you've drained, or you'll just be pouring...down the drain.
    But, unless you are vacuuming to waste, after you refill it's fine to add Polyquat 60%. It will tend to push your chlorine level down for 24-48 hours but it will inhibit new algae growth and acts as a clarifier as well.
    My husband is happy to have a game plan("I told you we should drain the pool!")
    Yes, we put the cartridge back in.
    More pool details:
    concrete reinforced fiber glass wall with a steel mesh reinforced floor installed in 2003
    Filter: Sta-Rite Series III 450
    Natural Gas Heater: replaced this year Sta Rite 400 btu/hr
    AO Smith Replacement Motor 1.5 HP (replaced 2008)
    PB 4 Booster Pump
    Hayward Chlorine Feeder CL 220(Replaced 2006)
    Nature 2 Cartridges
    Polaris
    Pool was painted one coat 2007
    He is shocking the remaining water now. Will keep you informed. thanks
    Just wanted to note that I am usually against the use of flocs/clarifiers myself, but having had a messed-up pool from filter blow-back for almost 3 weeks that no amount of vacuuming/shocking would fix, the clarifier I used was a last resort. The problem I had at the time was that the stuff was too fine for any filtering to get it out. So--that's why I suggest that you try the shocking first, to eliminate the possibility of algae. If shocking doesn't change anything, and your other numbers remain in line, then it might take a clarifier to remove the reallly fine stuff from the pool.
    That being said, I agree with Carl in that if you're going to drain the pool, go ahead and do that before adding anything else to it.
    Ok we drained over half of the pool and are filling it now. It still has a few thousand more gallons to go but my husband wanted the chemicals checked.
    ph is 7.4
    FC 22
    cc 0
    CYA 65
    TA 220
    So now the TA is really high. Hubby wants to sit tight until pool is filled and see what happens. He did add chlorine again. (this am FC was over 30) I read about the murantic acid/aeration method. Husband doesn't want to be chasing our tail as I am sure we made the TA high adding the soda ash and sodium bicarbonate.
    Like your situation, Janet, the flocculant we added did nothing. The bottom is perfectly clean so the particles were suspended although looking fairly clear so far with the new water diluting them.
    Thanks, Mary
    Quote Originally Posted by Mary eaton View Post
    If you continue to use this you will have the CYA problem again, especially if your System three is a cartridge or DE model and not a sand filter.
    Nature 2 Cartridges
    This is putting copper in your water. Copper is what stains pools and turns hair green. It IS an effective algaecide so the water doesn't turn green readily but, as you found out, it does nothing to prevent it turning cloudy. You are spending about $200 a year on carts for it and it realy doesn't do that much.
    Hope this is helpful.
    ok I am back with more cloudiness. This am
    FC 7
    CC 0
    ph 7.6
    Alk 200
    CH 130
    CYA 85 (not using pucks anymore)
    We have not run the Polaris (not fitting into the outflow for some reason), nor have we vacuumed (can't see bottom) The filter pressure is 18 which the usual. My husband thinks we need new filters but they don't seem that friable. I know we need to get the alkalinity down. Is there anything else you could recommend? Is there a particular flocculant that works better?
    Thanks, Mary
