Re: Ah, my 29K gallon hot tub.....
I think IG pools stay cooler as they are surrounded by the ground of five sides. Mine is about 85 degrees here in NJ, which I actually consider a little too warm. Maybe I should stop using the solar and keep the cover off, but then in a few weeks it will start getting cold, so I guess it is better to build the heat reservoir now.
