Thread: Bubbles in Return & Low Pressure
    Lutherville MD
    Default Bubbles in Return & Low Pressure
    After searching through the posts, I'm not seeing this specific problem, which is: at startup the pool pressure gauge showed normal pressure, and there were no bubbles from our returns. Now we're seeing large bubbles from one return, tiny ones from the other (closer) return, and the pressure gauge has dropped significantly. I've replaced the pump basket O-ring, and tightened all the fittings and various plugs. No change. Any ideas as to what to check now? By the way our pool was just remodeled, and has a new skimmer. The water level is not dropping either. All suggestions will be greatly appreciated.
    Smile Re: Bubbles in Return & Low Pressure
    Either the filter is congested or there is an obstruction in the suction line. At least that's my first and best guess Also check the wtrer level and skimmer weir.
    Lutherville MD
    Default Re: Bubbles in Return & Low Pressure
    Thanks - I also found a post that talked about the impeller being "clogged" so we just unclogged it and - miracle! - both the bubbles are gone and the pressure is normal. I love this Pool Forum :-)
  1. Bubbles in return lines
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 05-10-2012, 09:56 PM
  2. Air Bubbles in Return Lines
    By dnspade in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2011, 03:05 PM
  3. SWG and Bubbles from return??
    By Sardian in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-28-2007, 02:05 PM
  4. Bubbles from return
    By spcchap in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-25-2007, 07:52 PM
  5. Air Bubbles in Return
    By rrands in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 11:33 PM
