Results 1 to 8 of 8
Thread: leaky pool / insects / barrier for the bottom
    Scottsdale, Arizona
    Default Re: leaky pool / insects / barrier for the bottom
    Is a concrete slab an option ?
    CT
    Leslie's said that about using DE.
    Slab is not an option. I have a deck / fence / walkaround pool and the would essential mean disamantle and reassemble.
    I do have 12 holes now and they are all patched. If I keep the pool I am going to do a new liner in the spring. I will attempt to find and patch myself for the remainder of the summer.
    They are all around the edge and it is now spreading. There are holes approx. 1/2 around the pool.
    My spring plan of attack is to call the exterminator and get the area treated and do some sort of liner under the liner.
    When I had my liner replaced a few years ago, I had them cut out the floor of the old liner and leave it on the ground under the new liner. Just another layer for roots and grass to have to get through. There was also a layer of foam put down between my old liner and the new liner. Good luck keeping the holes patched for the remainder of the year. What a pain in the patooey!
    CT
    I contacted a dealer for my make of pool and they are offering the following:
    1. Treatment of the termites. They have two companies that do the spraying and offer a guarantee that if there is a leak due to insect damage , they will pay for the liner. One company offers an $80 a year "inspection" and that includes the water & labor for the liner. The cost is about $250 for the service.
    2. They repair / rebuild the base / remove any roots
    3. Replace the liner with a non-embossed vinyl liner (US Made)
    4. They were insisting my pool has an overlap liner. I told them that in 2002, the company offered a hung liner. My pool style (deck & fence & walkway) is not very popular around here. They sold more of the Esther Williams slat wall pools of my type. They then said that if my receiver is plastic and not the aluminum it may need to be replaced. That means taking off the top rail / decking. THIS IS THE REASON WHY I SPECIFICALLY WENT WITH A BEADED LINER!!! The receiver looks and feels sturdy to me and I have no issues with the liner.
    I am looking at about $1,200 (worst case scenario)
    The good news is after the last patching, I have no leaks. I plan on keeping the pool open perhaps to the end of September. If it holds water, I close it. If it leaks, I abandon it, make sure it does not go empty prior to winter and schedule the liner replacement for April of 2011.
