Re: another cloudy water ?
Ok i will beable to have a free time to dose the pool. How long should i keep the pool at 10ppm of chlorine? i will have from 6pm on sunday to tuesday at 6am where the pool will not be used. is that enough time for the chlorine to hit 10 and then come back down to acceptable levels to use.? or should i use the stuff to get the chlorine levels down? thanks for your help.
