I'm still trying to learn to adjust my chemicals myself. Here's what I tested this a.m.
I'm a 24'round above ground (13,000gals)
4.4 FC
no CC
7.8 pH
1 drop acid demand
150 TA
225 Ch
49/50 CYA
Also, FYI, I just fought off another algae bloom & pool is quite cloudy - never even cleared up from last time.
I think I need to do the following:
1/2 gal chlorine
1c muriatic acid
8.36 lb sodium bisulfate ???? (should I do this?)
Also - should I try a clarifier for cloudiness? Not sure how I can clear this up. Pump is running continuously - is not clearing up. I was reading about having too strong of a pump for the filter (blowing right back into water) - could this be the problem? My pump is 1.5 hp. Filter is a Hayward C-900.
Thanks very much,
Jennifer
