Re: New Pool Owner bought a test kit
Hi, Doug, and welcome to the forum!! We're glad to see you here.
Sounds like you've been doing your homework--congrats! You'll find it so much easier and cheaper when you have control over your own pool and are not at the mercy of the pool stores, as you've already found out.
Just have a couple of comments....First off, your CYA level is high, which is from use of the trichlor pucks. I would now discontinue the pucks and switch to another means of chlorination. Because your CH is also high, I wouldn't use any more cal-hypo (probably the ingredient in the powdered shock you've been using) so your best bet is to switch to bleach. With a CYA of 90, that means you need to keep your chlorine level at 5-10 ppm at all times, so your chlorine is a tad low. Since you're already at the upper end of the CYA range, I would try to keep the chlorine level at the upper end of that range, as well.
Your CH, if it were low, wouldn't be an issue in the vinyl pool. However, with it being high, if you continue to use cal-hypo you are going to end up with milky water that will not filter out. So...if the water is clear now, that's great--but I wouldn't use any more calcium for chlorination.
Your alk is a little high, but ok for vinyl, as well as your pH. You could leave them alone, or wait until after you decide what to do about the CYA and CH to adjust them. Also, if you'll be closing the pool for winter, it's probably best to wait until you open in the spring to adjust them anyway. I strongly recommend that you drain/refil about 1/2 of your water, if that's feasible for you, in order to lower your CH and CYA levels to something a little more manageable. In very hot, humid, sunny climates like mine, high CYA is a good thing and helps cut my chorine useage, but in most other pools, it's better to keep it a little lower (30-40) in order to be able to maintain lower chlorine levels. It's up to you, but it's a suggestion. Also, if you're going to close the pool for the winter and don't do it properly, algae that blooms over the winter can allow bacteria to break down the CYA into byproducts, including ammonia, that create a huge chlorine demand upon opening until it's all broken down. (Just another reason to consider lowering the CYA before winter closing). But again, it's your call.
Since you're using well water, have you had it tested for metals? Well water often has iron in it, which can create a whole other group of problems, so if you haven't had it tested yet, I advise you to do so before you decide whether to drain/replace water or not.
Otherwise, it looks like you're on the right track--congratulations on the new home and pool!!
