2 * 0.5 = cc of 1, not 10--that makes a lot more sense. Get your chlorine back up to 20 ppm--if you let it continue to yo-yo up and down, it's not going to clear up. Consistency is the key!!
Also, you don't need to continue testing for CYA each time--that number shouldn't change unless you're doing a huge amount of draining/refilling, or using chlorine that contains stabilizer. Save the reagent unless you start using trichlor or dichlor (which I wouldn't, because your CYA will easily get out of control if you do).
