Results 1 to 10 of 15
Thread: Which kit to get?
    Default Re: Which kit to get?
    The CYA test is one you don't need to test too often. If yours is at 30, you're in a pretty good spot. You might just try leaving it there. If you find that you can't keep chlorine in the pool through a hot sunny day, you might later decide to bump it up to 40 or 50, but for now I say leave it alone. You can always buy some replacement CYA reagent if you need it. For now, you don't need to test it again.
    You need to keep your chlorine between 3-6 when your CYA is 30. Your readings look pretty good. The only recommendation I'll give is to suggest that you just use bleach for your source of chlorine so your CYA doesn't go up any right now. Also, no cal-hypo. Your CH reading doesn't need to be any higher either.
    I agree with Lisa that you don't generally need to test cya often, unless you are sing trichlor or dichlor for chlorination, which I wouldn't in your pool. However, you can get cya reagent in much larger quantities online, and occasionally my pool store has been known to give me some...
    Largo, Florida
    I'm on a swcg, but it's been turned down real low for the winter since I ran the pump every day for four hours all winter. Also, the sample was taken at about 4pm which is right before the system starts.
    Also, I looked for the booklet. Apparently Taylor sells it separately rather than just giving the information away. Guess everyone's gotta make a buck! http://www.taylortechnologies.com/pr...entPartID=2084
    Largo, Florida
    That surprises me that the booklet isn't in your kit. I bet you can find the information online if you google for it.
    No, the booklet was in the kit. I was just commenting that it was really good info and hoping to find a copy online to share with others.
    Quote Originally Posted by kelemvor View Post
    Actually, while much of the book is good there is a bit of misinformation in it so do not take it as gospel.
    Hey Gang! Ben, glad you are back!
    My Old PS 232 needed updating after 10 years of a "Never Green Pool" so I came back to the folks that got me started!
    As ben is no longer marketing kits I'll follow the above link and give him the credit!
    100F here yesterday, water at 60F so time to get busy!
    Ken T.
    Hi txhomebrew,
    Thanks for the order from the link, and it's good to see you back on the forum again!!
