Results 1 to 8 of 8
Thread: Time to start warming her up!
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Thumbs up Time to start warming her up!
    Well, I did a 50% drain this winter to alleviate a high calcium condition, re-added salt, re-adjusted TA. Next weekend we'll cut the new cover and start warming this pup up for season 5!
    Water Tmp: 53 degrees
    FC: 2 (10% output from SWCG for winter)
    CC: 0
    PH: 7.6
    TA: 80
    CH: 460ppm (I know, but it beats the hell out of 800ppm that I closed with)
    SALT: 2600ppm (2250-2750 range)
    CYA: 70-80
    Once I get her warmed up to above 65 degrees, I'm tackling my iron stains next. At the end of this swimming season, I'll address the CH level again. I thought I had drained plenty---but I guess I didn't.
    Default Re: Time to start warming her up!
    Joiining Watermom to say glad you're back, and looking forward to seeing you around here this spring/summer.
    Incidentally, what is the CH of your fill water? Could be you did drain enough--but if the fill water is high, it will limit how low you can get your CH without a different water source.
    Hi Steve!
    I don't even BEGIN to think about opening until mid-April, and only if the ice has melted. I expect a full pool from all the snow melt--the cover is STILL weighted down with snow and ice (now mostly ice).
    Hey Carl, will you be mad if I tell you that my trees are budding? Y'all can keep the ice. This girl is glad to see signs of spring. I'll be putting the pump and filter on my pool within the next 2 or 3 weeks so I can start chlorinating. If I don't, as the weather warms up, I'll have a green pool!
    Southern Arizona
    If I remember correctly, I think my fill water is about 220ppm.
    Y'all can keep ALL of the winter/cold stuff up there--we've got flowers blooming, temps in the low 70s during the day and mid 40s at night, and my pool got its first shot of chlorine a couple of days ago. It's crystal clear, just waiting for the water to warm up--it's still in the low 60s at the moment. Got a bad case of Spring fever now!!!!!
    Southern Arizona
    Hi Steve!
    Our climate is so moderate, I never close my pool. I do lower my SWCG to 5% output, which keeps me at 2ppm. usually around mid-March we'll cover it up, and start building some heat; and then I'll clean my filter elements and my salt cell.
