Re: Baquacil to Chlorine Conversion Procedure
Day 5: Pool is still crystal clear. Total bleach so far = 38.7 gals 6%. Pump pressure holding steady since yesterday's backwash.
FC dropped 1.5 ppm, and CC increased .5 ppm overnight. Should I contine to add bleach in large quantities, or reduce to more normal levels? What is the probability the pool may never reach the recommended level (.5 ppm CC, and less than 1 ppm FC loss overnight)?
Here are the overnight readings:
Sun 6:30pm
3.5 ppm FC
1.0 ppm CC
7.2 pH
Mon 6:00am
2.0 ppm FC
1.5 ppm CC
7.2 pH
