Results 1 to 10 of 39
Thread: Baquacil to Chlorine Conversion Procedure
Threaded View
  1. #24
    Default Re: Baquacil to Chlorine Conversion Procedure
    Patience, patience, patience!! That's the hardest part of this whole thing sometimes!!
    Your Cl is going to drop to near zero during the day until your CYA is there to protect it from the sun. I would not add any of the fast-acting stabilizer since you've already added the granular form, because if you overshoot your CYA target, the only way you're going to be able to lower it is drain/refill. Just add your bleach every day (at night if possible to give it the most time to be effective, and then again in the afternoon if it's at zero) and give the CYA a few days to dissolve. You've put all this work into a beautiful, clean pool--don't get in a hurry and create a whole 'nother problem for yourself!
