Results 1 to 10 of 14
Thread: DE in pool
    Default Re: DE in pool
    Welcome to the forum!
    I'll trust that the grids are fine and the multiport gasket is good.
    How about the o-ring that seals the manifold to the return pipe? Also, are the 'fins' on the top of the grids whole and fully seated in the manifold, AND the fabric all the way up and, at least, to the manifold?
    We're running out of places for DE to get through the system, so I hope it's one of the things I mentioned
    Mar 2011
    Cibolo, Texas
    yes I checked and did all those things. Maybe its the way I am vacumming? How should the skimmer covers be when you have two skimmers?
    I trun one to close off the top hole and plog the center hole on the cap. The other I turn to close of the top whole on the skimmer and put the hose in the top of the cap?
    Without one one of above things being wrong, the way you vacuum doesn't affect DE going back into the pool
    Please check over all the things discussed here - mayhaps you missed a little something somewhere
    That's the best I can offer
    Mar 2011
    Cibolo, Texas
    Thanks,
    Thats what I paln to do, I don't know what else it could be.
    Mar 2011
    Cibolo, Texas
    Well today is the day I tear it all apart and try to remedy the problem again.
    I have pretty much decided if I cannot resolve the issue I may replace the filter. I love the DE becuase it cleans so efficiently but I can't deal with the issue of it getting into the pool evrytime I do a filter cleaning.
    I know there are pro,s and con's for all three but I would like to get some feed back on the type and brand I should go to if I switch?
    I personally am a sand filter fan....my sand filter does just as good a job as any DE filter could, and if I needed better filtering, I can always use a handful of DE to get the benefits of the DE filtration without the hassle--this is a trick that the other 3 mods all use with their sand filters. Just make sure that if you do replace your filter, that it is adequately or over-sized for your pool and pump--many people make the mistake of buying undersized filters, and that will result in the pump just pushing the filter media back into the pool.
    Apr 2011
    I have used de filters in the past and have found that it will find its way through any areas that it can into the pool, especially after a pump start up when it is wanting to adhere to the grids and there are any holes bigger than a pin in the mesh.
    Last edited by Watermom; 04-04-2011 at 09:39 PM. Reason: oops! hit the edit button instead of the reply button!
