I agree with Janet. Using dichlor right now is a good idea as it will add chlorine, cya and help lower pH. If, after a bit of time using dichlor, if your pH is still too high, then you can use acid or pH-down to lower it, but for now, I'd just try the dichlor and see how much it affects your pH. Glad to see you back here on the forum this year!
