Results 1 to 8 of 8
Thread: High PH
    Dec 2005
    Jupiter, Fl.
    Default Re: High PH
    Ben,
    I know that you speak the truth sir! This forum has been INVALUABLE to me over the years. You did not , however, answer my question. Please explain to me the procedure for adding Borax to my pool. Numbers are posted previously on this thread. Thank You in advance!
    I live in South Florida. I have owned my first pool for 6 years now. 12,200 gal. with exposed aggregate finish, spa with spill over, cartridge filter, pop up bottom cleaning jets, Chlorine by swg. I am eternally grateful for The Pool Forum!!
    15'x30' Rectangle w/ ovals at ends 12.2K gal IG pool; Bleach now as SWCG died.; Hayward 1200 cartridge filter; Emerson 2HP pump; 6hrs; Taylor K-2006 La Motte Borate Test Strips; utility; summer: ; winter: ; iPad; PF:9.8
    Default Re: High PH
    Hey 'Bear! Nice to see you out of "hibernation"!
    That was a great post on Salt water generator levels!
    My pool is still closed but I'm hoping to start opening Saturday. First I have to move the filter wiring as we have a new deck extension. Then I recruit my teen to do the heavy lifting! I would have done it sooner but family issues and a cruise got in the way....
    Default Re: High PH
    Hey Carl! Been here off and on all winter! You know you're not gonna get rid of me around here unless you ban me! (Now don't go getting any ideas!)
    Apr 2011
    virginia
    Default Re: High PH
    Denny, you can add borax in the skimmer slowly...
    it will dissolve and spread from there- just don't put it in so fast you clog anything!
    and like most balances, add it over time- I recommend no more than 1/4 dose a day, so spread out what you need for your pool over 4 days.
