Thread: Solar cover question
    Jun 2010
    South MS
    Default Solar cover question
    What is the best use of a solar cover? Do you leave it on during the day too or just at night? We just bought one. Thanks!
    Tricia from South MS
    Intex Above Ground Metal-Framed Pool 15' x 48" (~5000 gallons) installed 6/21/10, and now using BBB (well only one of the B's so far) and Taylor K-2006 test kit
    Default Re: Solar cover question
    You usually leave it on during the day as well, especially if it is at least somewhat opaque, since that will reduce chlorine loss during the day from sunlight. Having the cover on during the day will also reduce evaporation (and subsequent refill assuming you have an auto-fill) so will keep water parameters such as TA and CH from rising from the fill water. You generally take the cover off when you want to use the pool. You might find that the pool is too warm during the hottest part of the summer in which case you could take off the cover some nights to cool it. If the cover is mostly clear, then taking it off during the day will also work since it will reduce the temperature of the water via evaporation.
    If you aren't using the pool regularly, you should still take the cover off at least once a week or so to have the pool air out and get some exposure to the UV in sunlight. This helps prevent formation or accumulation of some disinfection by-products.
    The biggest benefit offered by a solar cover is to reduce heat loss at night when the nights are a little cool. Without it on the pool, you can watch the pool "steam" at night when the night time air is cooler than the water. This is most helpful in the spring/early summer and then in the late summer/early fall. It can help extend your swim season a little. (It isn't actually steam but that is just a good way to describe it. It actually is warm water evaporating and then condensing in the cool air to form a fog.)
